Shutdown after render
OfF3nSiV3
by OfF3nSiV3 » Sun Aug 24, 2008 12:54 am
Is there the obvious shutdown after render feature?
That would be handy.
DrSlony
by DrSlony » Sun Aug 24, 2008 1:18 am
Or a 'run command' feature after render, shutdown being one of the possible commands. Being able to 'run command' would also be a workaround for the problem many users have of the "render donee sound" not working, although a workaround isn't as good as a fix. Making the "render done sound" play on all platforms/setups would be a fix and therefore better.
