wishes
ckiely
wishes
by ckiely » Mon Dec 19, 2005 8:54 am
1) remembering my last folder... everything seems to go to Open or Save to Desktop which is a bit annoying.
2) rotate 180 degrees... my images always diplay 180 inverted and I have to go thru two 90 degree turns to get a finished product to display
bilzmale
by bilzmale » Mon Dec 19, 2005 10:00 am
Agree that APP should remember last folder. Also remember last window size.
Lionel Laissus
by Lionel Laissus » Mon Dec 19, 2005 11:33 am
AutoPanoPro remembers the last folders.
Actualy APP handles 4 different paths 2 for .pano (load/save) and 2 (.panotools)(load/save).
About the window positions the "wish" will be added in the next version.
We are thinking also to replace the MDI windows (groups view and panos view) by only one window with a split bar inside... What is your point of view about that ?
THX
Lionel
APP Support
by GURL » Mon Dec 19, 2005 1:59 pm
llaissus wrote:We are thinking also to replace the MDI windows (groups view and panos view) by only one window with a split bar inside... What is your point of view about that ?
Split bar? how many photographers know of split bar and know they can be moved?
Lionel Laissus
by Lionel Laissus » Thu Dec 22, 2005 12:39 am
I guess your answer means that split bar is not a good idea ...
Actualy Split bar is just a convenient way to handle or not the document list view and pano list view inside the main window.
Thx for your answer
Matt_K
by Matt_K » Mon Feb 27, 2006 7:10 pm
In the edit mode, I would like the ablility to remove an image while doing the layer view.
