I was using a Gigapan Epic Pro for a long time and using the Autopano Giga - Gigapan plugin to stitch perfectly every time.
I have recently upgraded to the iPano, which is basically the same. Only slight differences, like shooting methods (rows vs columns etc)
I'd love to see an iPano module added. It should be rather easy to do I guess. I'm happy to help if I can. Basically the same as the current gigapan module- just a few more options.
virtualdiorama wrote:Im also a happy owner of an Ipano, agree with you that it would be great with plugin! Have you found a good way to stitch your pictures?
Best regards j.
I must use the iPano in the same shooting order that the Gigapan used, so I'm rather limited with the iPano until there is an Autopano plugin made. Pretty annoying
