Export/Import Cube faces
360panosi
Likes: 4 posts
Liked in: 7 posts
by 360panosi » Wed Feb 10, 2016 4:55 pm
It would be very nice to have an option to export panorama to cube faces with quality settings. Then option to Import cubes faces. If PTGui have this option then AutopanoGiga should too. :/
2 people like this post.
interactive360
Re: Export/Import Cube faces
by interactive360 » Mon Apr 18, 2016 8:07 pm
I second that suggestion. I like to be able to export to cube, so that I can fill in the space left by the tripod and then convert back to spherical to finish post processing the pano. This is an important feature for many users.
by Destiny » Tue Apr 19, 2016 3:32 am
Hi.. I did not know you could create a pano from cube faces back to a pano using PTGui.. I have often exported the cube faces from PTGui as TIFs for editing the Nadir footprint. But I then use PTP to build the pano back..
Amidee
Liked in: 30 posts
by Amidee » Fri Jun 24, 2016 1:50 pm
+1 I also had a little discussion with John Carmack nonetheless on Twitter about this... Cube faces are needed for a lot of things!
