Introducing a filename var %p for used projection
pstein
by pstein » Sat Oct 26, 2013 5:33 pm
When I render a new panorama and save the picture then the customized target filename format is used with e.g.
%i_%j %g
I miss here a new variable (e.g. %p) for the used projection.
This is extremely useful when comparing different variants.
Even more when I use "automatic" I would appreciate even some days later which projection (e.g. "hammer") was used for rendering.
Could authors introduce this tiny littly new var?
I think it is easy to implement.
Thank you
Peter
Re: Introducing a filename var %p for used projection
by mediavets » Sat Oct 26, 2013 8:53 pm
pstein wrote:When I render a new panorama and save the picture then the customized target filename format is used with e.g.
%i_%j %g
Thank you
Peter
Isn't this what you seek?:
