autorotate "tofov'
rbackhaus
autorotate "tofov'
by rbackhaus » Sat Dec 01, 2012 1:42 pm
Can an option be added to allow or disallow the the "tofov" parameter,...so that when a scenes fov is adjusted by a viewer via the zoom buttons to a preferred fov, they are not forced back to the the original setting upon the restart of autorotate.
<autorotate horizon="0" tofov="70" waittime="1" speed="2"/>
Thanks,
Rob
by klausesser » Sat Dec 01, 2012 4:06 pm
rbackhaus wrote:Can an option be added to allow or disallow the the "tofov" parameter,...so that when a scenes fov is adjusted by a viewer via the zoom buttons to a preferred fov, they are not forced back to the the original setting upon the restart of autorotate.
Thanks,
Rob
You can switch off the rotation - then the fov the user set temporarily keeps it´s value. Otherwise there´s no option afaik to keep the rotation to the fov the user set on his/her screen after the rotation starts again.
