Measure area
zooeyjfp
Measure area
by zooeyjfp » Mon Oct 15, 2012 6:30 pm
It wouold be very nice to be able to determine the visual magnitude of an element in a photo. This could be implemented by using the mouse to outline an element. Measurement should be in steradians or square degrees.
by klausesser » Mon Oct 15, 2012 6:45 pm
zooeyjfp wrote:It wouold be very nice to be able to determine the visual magnitude of an element in a photo. This could be implemented by using the mouse to outline an element. Measurement should be in steradians or square degrees.
You´d need stereoscopic photography for that if you want to be precise (and otherwise than being precise measuring would hardly make sense . . ;))
See here:
http://www.spheron.com/en/spheron-cgi/products/3d-measurement.html
zooeyjfp
by zooeyjfp » Mon Oct 15, 2012 6:52 pm
Klaus, Thanks, this is certainly true for real linear measurements, but I am interested in the visual area occupied within a field of view (measured in square minutes of arc).
The problem I am facing in to understand the visual magnitude of wind turbines in a view. It is not the absolute size of the turbines, but their relative size that concerns me. The closer one gets to a turbine, the greater the visual magnitude.
by gkaefer » Mon Oct 15, 2012 7:09 pm
http://www.kolor.com/blog-en/2012/09/07/kolor-labs-measurement-using-panoramas-by-alexandre-jenny/
by klausesser » Mon Oct 15, 2012 7:22 pm
Yep!
That´s the way Spheron shoots it: two POV.
by AlexandreJ » Tue Oct 16, 2012 5:14 pm
I like this idea much. Added to feature request : 1544
