option to not stitch single stack
foundation
Likes: 3 posts
by foundation » Thu Aug 02, 2012 5:24 pm
When using Browse folder I often find I need to go through and clean out groups of images that aren't panoramas.
For images that are a single stack, it'd be nice to be able to set a preference to not stitch those (also when a panorama is detected in a big group, where images are only from a single stack).
example 1:
group consists of
StandAloneHDRStack1
example 2:
group consists of
PanoStack1 PanoStack2 PanoStack3 StandAloneHDRStack1
it'd be nice when it finds 2 panoramas (PanoStack1,2,3 (9 images) and StandAloneHDRStack1 (3 images)) to not have it take up the resources of building preview.
I do like the ability to stitch stacks (your alignment works much better than HDR programs) I often don't want to do it.
Thanks!
by AlexandreJ » Fri Aug 03, 2012 1:08 pm
Issue 1442 opened
foundation
Likes: 3 posts
by foundation » Mon Apr 01, 2013 8:11 pm
while the browse folder, minimum number in a group option helps with this, it doesn't help where a group has a bracketed set along with other photos (so it meets minimum number for a group).
example:
I set minimum images for group to 4 to it doesn't look at a 3 image bracketed set by itself, but if I have a group:
stack 1,2,3
stack 4,5,6
it will stitch both of those as a panorama (which granted is useful for aligning handheld hdrs)
but it would be great to have a preference to tell it don't stitch if all images are in the same stack
Thanks for so open to suggestions here on the forum!
Akash98177
by Akash98177 » Tue Apr 09, 2013 7:31 am
I think when a panorama is detected in a big group, where images are only from a single stack.
foundation
Likes: 3 posts
Re: option to not stitch single stack
by foundation » Tue Jan 05, 2016 4:14 am
Well just made the mistake of running pano detection on a folder of 545 images (all bracketed hdrs) and every single stack was detected as a pano. Luckily the 130 panos detected didn't cause a crash!
I would like to reiterate the need to specify whether or not a single stack should be made in to a panorama in way, preference setting, or have the "minimimum photos in a group" also apply to minimum photos in a pano or ?
