PSB vs PSD files
ckiely
PSB vs PSD files
by ckiely » Sun Feb 12, 2006 8:57 am
When I go to render a file, the first option is a PSB file. The second I move the slider it switches to PSD file. What's the difference?
by AlexandreJ » Sun Feb 12, 2006 9:03 am
PSD : adobe photoshop standard format, limitation to 30,000 x 30,000 pixels.
PSB : large adobe photoshop format, can only be read using photoshop CS / CS2 : limitation 300,000 x 300,000 pixels.
An automatic switch between both formats happens when reaching the 30,000 pixels limits.
ckiely
by ckiely » Sun Feb 12, 2006 9:31 am
Mine defaults to PSB no matter what.
by AlexandreJ » Sun Feb 12, 2006 9:33 am
Just go to general settings, rendering option and tell the software which one you want as default.
ckiely
by ckiely » Sun Feb 12, 2006 9:39 am
Yes, it is already set @ PSD, and there is not even a PSB option.
francois.simond
by francois.simond » Sun Feb 12, 2006 11:51 pm
ckiely,
APP switches to the PSB format because resolution of your panoramas are so high ! To much for the PSD format ;)
If you set default render size to 10%, the default output format would be more often PSD.
Anyway, both formats are basically the same, except size limitations.
François Simond
