Mac feature request II: post processing...
refsvik
by refsvik » Sun Feb 12, 2006 3:31 am
Would of course like (in later versions) to have added all the features (and more) that are found in the CubicConverter. By that I mean that Autopano should:
-Output to desired high-rez format (photoshop HDR/ProRGB/32bit file) and then:
-Render the desired low rez projection
-if_cubic/spherical: Give the user the option to replace the nadir part of the pano with separate shot, or copyright logo
-output to desired low res Quicktime/Flash/Java pano
-Make the code (HTML/Java) to have it published on a webpage, fullscreened, autorotated, and save disabled, if the user so desires.
I know it is a very tall order, but then, this would be the ultimate app. I would only need Aperture and Autopano in my entire workflow ;-)
Best of luck
