EXIF importing
MFranquelo
EXIF importing
by MFranquelo » Tue Mar 13, 2012 3:08 pm
Hello!, i don´t know if this is possible but it would be nice to have an in-program possibility to import the EXIF data of any desired image , to the current project images, sometimes you loose all exif data when you create
.hdr files and you have to put it all again in APG manually.
Regards, Manuel.
by AlexandreJ » Tue Mar 13, 2012 4:28 pm
MFranquelo
by MFranquelo » Tue Mar 13, 2012 4:40 pm
Hmm, can you tell APG with the image properties, all the necessary EXIF info from a file ?
sorry for my ignorance :|
by AlexandreJ » Tue Mar 13, 2012 4:44 pm
What is important for sitching is first the focal length ( and the fact that an image is fisheye or not ).
This is a key value. Then the speed, aperture is here just for HDR.
BTW : autopano will transfer all other EXIF value from input to output ( if the format allows it ).
MFranquelo
by MFranquelo » Tue Mar 13, 2012 4:55 pm
Thank you for the clarification alexandre :)
