[feature requesst] change aperture value for all images with one klick
by gkaefer » Sun Sep 04, 2011 10:32 pm
I'm currently working on a pano shot with 85mm, 5 shots stack in sum 78x5 images.
I shot the pano with a SAMYANG 85mm (manual) lens, so no exif data is there...
the Camera saved the exposure time in exif.
it would be wonderful to be able to edit the according aperture value in the Image properties menue:
I can mark all images with CRTL-A. it would be great to have a text field where I can fill in my aperture value and than by pressing one button to apply the value to all marked (in my case all) images.
Liebe Gruesse,
hankkarl
by hankkarl » Wed Sep 07, 2011 6:34 pm
If this is in the pano editor, I'd also like to be able to change focal length of all images with one click.
HansKeesom
by HansKeesom » Wed Sep 07, 2011 6:44 pm
So we would like checkmarks above each column which when checked mean a change for one cell means a change for the whole column?
Regards, Hans Keesom
by gkaefer » Thu Sep 08, 2011 1:28 am
HansKeesom wrote:So we would like checkmarks above each column which when checked mean a change for one cell means a change for the whole column?
sound logic and simple too ;-)
by AlexandreJ » Thu Sep 08, 2011 8:05 am
In layer editor, the columns that are editable, you can select the rows that you want to modify with standard shortcut ( CMD / CTRL or SHIFT ), then use F2 to enter the modification mode. Apply, it will apply the entered value to the whole column.
by gkaefer » Thu Sep 08, 2011 12:15 pm
AlexandreJ wrote:In layer editor, the columns that are editable, you can select the rows that you want to modify with standard shortcut ( CMD / CTRL or SHIFT ), then use F2 to enter the modification mode. Apply, it will apply the entered value to the whole column.
;-)) thanks for this "bugfix"
Liebe Gruesse,
pauldu79
by pauldu79 » Thu Sep 08, 2011 2:31 pm
chaussures et vêtements Guess who just found a great answer here ?! thanks a lot for your help !
