AutoPano Giga 2.6 beta +LR integration
mcapellari
by mcapellari » Fri Jul 15, 2011 4:49 pm
i like the lightroom integration in AutoPano Giga 2.6, but some optional features would be nice
1. clean the temporary exported images after rendering the pano (normally there is no need to keep them, since the images are already kept in lightroom)
2. reimport the rendered pano in lightroom
3. start detection automatically after autopano has started
i'd love to see those features in one of the next autopano versions, would be nice if this features could be turned on/of somewhere in the settings, if they will be realized
Lionel Laissus
by Lionel Laissus » Mon Jul 18, 2011 1:03 pm
issue 800 opened
Will try to add point 1 & 3 for the next version
mcapellari
by mcapellari » Mon Jul 18, 2011 4:40 pm
hello lionel,
thanks for your reply,
i did not take a closer look at the autpano plugin for lightroom, is it a compiled lua script or is it plain text? i ask, because it maybe nice if it would be open for enthusiastic users, to add their own features
i also have some other ideas ...
- optional exporting as tiff instead of jpeg
- define exporting quality in the lightroom plugin (normally i would do the best possible quality, but for testing lower quality-settings could be usefull)
brunchto
by brunchto » Wed Jul 20, 2011 9:01 pm
To reimport into lr, you can use lr folder watching and set up apg to rendre in this folder. At the end of the render, the paon will be automatically imported in lr.
Lionel Laissus
by Lionel Laissus » Thu Jul 21, 2011 2:56 pm
mcapellari wrote:hello lionel,
It's plain text
So feel free to add your enthusiasm in it :-)
I'have to dig into lightroom more for doing what you asked for ...
kevshu
by kevshu » Fri Jul 22, 2011 11:54 pm
I've modified the export script to have additional menu entries plus I kept the original.
Fullsize TIFF
800px TIFF
I've included the fullsize tiff and 800px tiff .lua files with a modified info.lua.
http://exposedbykevin.com/downloads/apg_lr.zip
Just copy these files into the existing C:\Users\xxxxxx\AppData\Roaming\Adobe\Lightroom\Modules\AutopanoGiga.lrplugin folder.
Cheers! :)
Kevin Schumacher
Canon 5Dmk2, 15mm Fisheye, 24-70mm, 100mm Macro, 100-400mm, Nodal Ninja 3
Orion GoTo Mount, BT Ver2 Module, Papywizard on Fujitsu LifeBook U810
