Little planet generator ?
bzh360
by bzh360 » Wed May 18, 2011 8:12 am
Hi.
Generating LPlanets is possible from a pano using Photoshop or some other tools.
With the square re-sising and polar coordinate filter, the results are quite different from the one generated by APT as intro. The vertical are bended and it gives a poor result in comparaison with the the nice and straight planets made by APT.
Is there any future for a LP dedicated tool in APG in order to generate big and High def files ?
Does any one have a solution to generate APT like LP ?
Kenavo.
Toegha Prod. - Createur d'Images Elargies et Rotatives.
http://corryvreckan.fr/test/index.html - Follow us on Facebook
marco-pano
by marco-pano » Mon May 23, 2011 10:37 am
Little Planets generated by KrPano (then by Kolor PanoTour) used a stereographic projection which is different than squared / polar filter under PhotoShop.
From your equirectangular 360°x180°, you can try with Panini application
http://sourceforge.net/projects/pvqt/
which is no more compatible with my Graphic card.
Or try with Hugin
http://hugin.sourceforge.net/
using stereographic projection with pitch 90°.
Good luck.
Marco, Paris ;)
PanoMonster
by PanoMonster » Mon Jun 06, 2011 10:52 am
i would love to have such a feature in autopano!!
i have MediaChance Dynamic Photo HDR and that has a feature to create LP pictures but i would realy love to have it in autopano.
by klausesser » Mon Jun 06, 2011 11:11 am
bzh360 wrote:Hi.
Kenavo.
Using the "polar coordinates" filter in PS for that purpose you need to mirror the image and change the aspect ratio to 1:1 first - then use the filter. That works fine.
by AlexandreJ » Mon Jun 06, 2011 5:26 pm
All these extra projection are planned in autopano v3 ( pannini style, stereographic, and many more ).+
Michael Ezra
by Michael Ezra » Tue Jun 07, 2011 4:37 am
So anxious to see it Alexandre. I have upgraded to 2.x a really long time ago, but truly have not rendered a single pano for over a year...
