Auto-stereo settings based on file names
Mr360
by Mr360 » Sat Mar 04, 2017 7:45 pm
Please forgive if this has been suggested, I'm new here ;)
I, and I'm sure many people, use a naming convention on their files. Ex: I use 'Left_01' and 'Right_06' in my file names. I'm doing 13-camera 3D 360, so there's also an 'Up' camera, with file name containing 'Up'
So, an OPTION would be nice, to look for substrings like 'left', 'right', 'up' 'down' etc. and automatically select 'left only' 'right only' 'both' etc. in the Stereo settings.
I understand everyone is different, so this might take a configuration page where the substrings are specified (can be for different languages to map to 'left' and 'right' for example. Option to ignore case. Things like that. This would knock a minute or two off my process, which, when I have 100 clips to process, is a couple of hours just to set these stereo settings.
thanks
Skaven252
Likes: 4 posts
Liked in: 4 posts
Re: Auto-stereo settings based on file names
by Skaven252 » Sun Mar 26, 2017 7:07 am
As different people use different naming coventions it could get tricky. But it could also be helpful if the stereo menu's footage list would allow you to select multiple clips with Ctrl-click and then simultaneously set all their modes at once?
