Export each camera individually?
TomVR
Liked in: 5 posts
by TomVR » Sun Jan 10, 2016 7:39 pm
For example doing more advanced stitching in other programs like after effects or any vfx work it would be great if there was an option to set autopano video to export each video independently with the color matching.
crazy_rabbit likes this post.
crazy_rabbit
Likes: 8 posts
Liked in: 5 posts
Re: Export each camera individually?
by crazy_rabbit » Mon Jan 11, 2016 2:24 pm
This would also make it easier to work with layers of the video that overlap.
Co-Founder and Chief Creative Technology Officer
Vesmir.agency
http://www.vesmir.agency
TomVR
Liked in: 5 posts
by TomVR » Mon Jan 11, 2016 4:52 pm
Rotoing tools are much much more advanced then the marker based stitching too, which means you can really refine how the cameras overlap.
tuli-panos
by tuli-panos » Thu Mar 10, 2016 9:00 pm
just registered to request this feature. similar to what PTGUI does when you render out a layered psd file. it's would be great to have each video rendered out preferable with color tweak added as an option and with a mask. then i can import into ae and tweak the stitch further as needed.
mandivision
by mandivision » Mon Apr 04, 2016 6:14 pm
This would be extremely useful.
Tim Baier
by Tim Baier » Mon Jun 20, 2016 11:09 am
The lack of this feature is killing me at the moment.
Independent access to each layer is an essential feature.
Amidee
Liked in: 30 posts
by Amidee » Mon Jun 20, 2016 11:42 am
+1 This would be great
Tim Baier likes this post.
joshlgibson
Likes: 3 posts
by joshlgibson » Fri Jun 24, 2016 5:08 am
Yes yes yes.
TomVR
Liked in: 5 posts
by TomVR » Thu Jul 07, 2016 6:43 pm
Autopano giga already supports openEXR. Why not drop the useless Tiff rendering option and allow us to render a multichannel EXR image sequence? Main channel being the full stitched comp and every subsequent channel being each camera in the stitch isolated with alpha channel.
To really be great there should also be an option to render out a "directors view" rectilinear pass of a comp that contains metadata of the Pan/yaw/tilt that can then be reimported into AVP and reprojected onto the latlong comp.
The way I work with other artists is I make a virtual camera that tracks around the latlong to render out areas as regular rectilinear footage. This normal footage can be easily handled by normal VFX artists for clean up or paint work or whatever else. When I get their finished plates back I then project their plate back onto the latlong through the same virtual camera.
Now for me to do all this requires extremely heavy scripts and $20,000 (that's the correct number of zeros) worth of compositing and vfx software. I need to do this it this way because I work with clients that demand a flawless stitch and don't care how much it costs.
Bringing this sort of functionality to AVP means instead someone with AVP, APG, premiere and and after effects can do 80% of what I can do. for 10% of the cost.
cgolheiros likes this post.
cgolheiros
by cgolheiros » Wed Jul 27, 2016 10:53 pm
there is a way to do it, although tedious and it lacks alpha channel.
solo check the visibility of the camera you want to render in APG.
back in AVP only that camera shows up. in black background(no alpha). Send to render.
-do the same for all other cameras.. yeah boring..:P specially if you have a 16 camera rig.
by Annis » Thu Jul 28, 2016 8:20 am
cgolheiros
by cgolheiros » Thu Jul 28, 2016 10:53 am
Well AVP 2.5 beta 2 is rendering black. Not much use for that. Not even Mp4's.
alpha version rendered really weird tiled prores.
by Annis » Thu Jul 28, 2016 11:02 am
Any feedback for AVP 2.5 has to be posted here: viewforum.php?f=124
Without feedback, we can't find the bugs to fix them.
