Linux version ?
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
Linux version ?
by vincen » Tue Feb 18, 2014 12:31 pm
Any idea when Linux version will be at least avalaible ? Indicated as soon since too long time on website :(
Re: Linux version ?
by AlexandreJ » Fri Feb 21, 2014 2:28 pm
For AVP, we have one already. Not public as highly untested.
You want to try at your own risk ?
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Sat Feb 22, 2014 3:44 pm
AlexandreJ wrote:For AVP, we have one already. Not public as highly untested.
Sure ;)
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Thu Apr 03, 2014 10:07 am
An update about it ? :)
fixer
Likes: 3 posts
Liked in: 3 posts
Re: Linux version ?
by fixer » Mon Jun 29, 2015 8:33 pm
Any updates/progress on a Linux version? Still needing testers?
fix.er \'fik-s*r\ n : one that fixes : as : one that intervenes to enable a
person to circumvent the law or obtain a political favor : one that adjusts
matters or disputes by negotiation
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Tue Jun 30, 2015 5:53 am
fixer wrote:Any updates/progress on a Linux version? Still needing testers?
Linux version is avalaible since a while and works really great (out of few cosmetic bug in layout of app) ! You can download it here: http://download.kolor.com/avp/stable/history
fixer
Likes: 3 posts
Liked in: 3 posts
Re: Linux version ?
by fixer » Thu Jul 02, 2015 9:28 pm
I am using ProRes files so I would need 2.2.0b3 - if your Linux version will be supporting ProRes?
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Fri Jul 03, 2015 5:57 am
fixer wrote:I am using ProRes files so I would need 2.2.0b3 - if your Linux version will be supporting ProRes?
Beta 4 is avalaible for Linux ;) http://download.kolor.com/avp/beta/history
Re: Linux version ?
by Annis » Fri Jul 03, 2015 1:16 pm
I just want to clear this up, since Vincen is posting the links to the download history pages.
Linux versions are available from those pages, they were made available for users who were demanding a linux version no matter the state of it, but they come with a warning:
  • - Those versions are not guaranteed to work. If it works, great, if they don't then we can't do anything about it.
  • - You are using those versions at your own risk.
  • - No support is offered for those versions.
  • - A definitive working Linux version won't be available until a solution for the video players in Autopano Video compatible with most Linux distributions is found. At the moment there are just way too many variables to offer a viable solution.
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Fri Jul 03, 2015 1:26 pm
Annis wrote:A definitive working Linux version won't be available until a solution for the video players in Autopano Video compatible with most Linux distributions is found. At the moment there are just way too many variables to offer a viable solution.
No solution with VLC that exists I guess on most Linux platform readily avalaible no ?
Re: Linux version ?
by Annis » Fri Jul 03, 2015 2:29 pm
We already use VLC 2.2, but it's not officially distributed with Ubutnu 14.04 so there are often conflicts, which is a problem that we can't systematically solve.
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Sat Jul 04, 2015 8:22 am
Annis wrote:We already use VLC 2.2, but it's not officially distributed with Ubutnu 14.04 so there are often conflicts, which is a problem that we can't systematically solve.
I guess you want to keep unity of GUI between OSes but why not remove VLC of AVP package and add an option in app to indicate pathway to VLC for Linux version ?
wojtekgr
Re: Linux version ?
by wojtekgr » Thu Jun 23, 2016 10:18 pm
What's the progress on the linux version of Autopano Video Pro? I would rather use linux for my video stitching.
Since the OFFICIAL FAQ states "Our software can run on Windows, Mac and Linux. Virtual Machines are unsupported." why is it not the case?
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Fri Jun 24, 2016 5:45 am
wojtekgr wrote:What's the progress on the linux version of Autopano Video Pro? I would rather use linux for my video stitching.
AVP is running since a long time on Linux (it's just not officially supported) but it works fine so far ! Few things are not working like the new USB auto import of videos, but nothing really important !
Virtual machines are not supported as it needs a full unrestricted access at graphic card (which is not possible in most of virtual machines).
Blog: http://www.skivr.com
Emeric
Likes: 3 posts
Liked in: 14 posts
Re: Linux version ?
by Emeric » Fri Jun 24, 2016 9:38 am
While we still don't offer support for the Linux version, the package of the version 2.5 will support more Linux distributions!
vincen likes this post.
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Linux version ?
by vincen » Fri Jun 24, 2016 10:57 am
Emeric wrote:While we still don't offer support for the Linux version, the package of the version 2.5 will support more Linux distributions!
Very cool ;) thanks Emeric !
