Template for stitch
Kolor Certified Trainer
Template for stitch
by mattmascheri » Fri May 31, 2013 4:56 pm
Hi this is a question about Giga / feature request for Video....
I would really like a quick way to save out a template from a reference panorama and apply it to a second stitch done for the same video sequence.
I can save out a template in Giga, but how do I then re-apply it to a new stitch?
Can this template export / import be applied directly in Autopano Video at some point?
Matt Mascheri
Dome3D LLC
Fulldome and 360 video producer
Freedom360 distributor
by AlexandreJ » Mon Jun 03, 2013 8:22 am
Yes, it can. Just save the .pano, then use apply template, select it, done.
