Page 1 of 1
Render error
PostPosted: Fri Apr 13, 2018 11:59 am
by JuusoV
Hey there
This error had not happened before, but now is prominent and makes the software unable to render anything, and exists across different versions of Autopano Video Pro. Current version is 2.6.2 64-bits. Help?
i7-6700
GeForce GTX 1080
32 GB
Thanks!
Re: Render error
PostPosted: Mon Apr 16, 2018 9:50 am
by martin.arnoux
Hi !
Can you try to render to another path? I'm worried that your output "path + filename" might be too long.
Also have you been able to successfully export files using the same settings and the same input types?
Thanks,
Martin
Re: Render error
PostPosted: Tue Apr 17, 2018 10:03 am
by JuusoV
Hi
No, it doesn't help. Everything used to work in exactly same settings and export paths.
Re: Render error
PostPosted: Tue Apr 17, 2018 3:17 pm
by martin.arnoux
Sorry I meant changing the source locations for a quick test. Could you try that please?
Cheers,
Martin
Re: Render error
PostPosted: Tue Apr 17, 2018 3:44 pm
by JuusoV
Tried rendering from local drive to local drive, doesn't work.
Re: Render error
PostPosted: Mon Apr 23, 2018 8:01 am
by JuusoV
The issue is still unresolved.
Re: Render error
PostPosted: Mon Apr 30, 2018 9:26 am
by olivierbo
Did you copy the files to a folder like C:\Videos\Test\filename.mov for instance?
What has changed on your system as it worked before?
Best,
Olivier
Re: Render error
PostPosted: Tue May 01, 2018 5:46 pm
by JuusoV
Hello
As stated above, rendering from local drive to local drive did not resolve the issue. Nothing has changed on the system, apart from reinstalling Windows 10, after which this problem occurred.
Re: Render error
PostPosted: Fri May 04, 2018 10:18 am
by JuusoV
We got a brand new workstation and the same error persists.
HP Z4
Intel Core i9-7900X 3.3GHz
64GB DDR4 2666MHz ECC
GeForce GTX 1080
Windows Pro 10 Build 17134
Re: Render error
PostPosted: Mon May 07, 2018 9:41 am
by JuusoV
I would appreciate more interest on your part on actually solving this problem. We have productions lingering because of a malfunctioning software.
Re: Render error
PostPosted: Wed May 09, 2018 9:41 am
by JuusoV
Still waiting.
Re: Render error
PostPosted: Thu May 10, 2018 2:03 pm
by JuusoV
The issue still persists. I also tried on a third computer and now instead of decoding pipe error it instead outright crashes when trying to stitch.
