Stitching merging problem   [SOLVED] - View the solution
Green
by Green » Sun Jan 21, 2018 10:30 pm
Is there any option to control stitching through video? For example setting keyframes or automatic check through the entire video?
I'm rendering videos in software where you cannot precisely set cameras angle through entire movement. Time and positiotion of cameras are the same but angles are changing through timeline. The results look like in attachment.
Thanks!
olivierbo
Liked in: 133 posts
Re: Stitching merging problem
by olivierbo » Mon Jan 22, 2018 3:21 pm
Did you apply the same blending between the preview window and the rendered video? If the automatic blending cannot correst the issue, you can check the stitching quality (Compute RMS curve tool).
Can you give more details about your workflow?
Best,
Olivier
Green
Re: Stitching merging problem  [SOLVED]
by Green » Mon Jan 22, 2018 6:40 pm
Yes it is the same blending. After your reply I used RMS and adaptive stitching. Now the results are good. Thank you for reply!
olivierbo
Liked in: 133 posts
by olivierbo » Tue Jan 23, 2018 9:32 am
Great!
Good continuation.
Best,
Olivier
