Broadcaster 3x Template problem
rfendelman
by rfendelman » Thu Apr 21, 2016 6:16 am
I'm following the instructions. Shot my 3 cam Hero 4 Blk at 2.7k. Brought into AVP, synced it, selected use 'Template Panorama' in the stitch window and chose the 2.7k indoor template I downloaded. Got a message that said wrong file.
There is a 2.7k S, could that be it. I tried the 1440 and that didn't work either. I'm running AVP 2.3.2
I'm using the Freedom 360 Broadcaster 3x housing for the cameras.
olivierbo
Liked in: 134 posts
Re: Broadcaster 3x Template problem
by olivierbo » Fri Apr 22, 2016 12:43 pm
Do you have the 3 modified cameras with an Entaniya lens? Which mode are you using? 16:9 or 4:3? Do not use the Superview mode.
Let me know.
Kind regards,
Olivier
rfendelman
by rfendelman » Fri Apr 22, 2016 1:08 pm
I'm using the three camera setup with the 220 lenses.
I tried shooting in 1440 and 2.7k.
I tried stitching making choices with the following
Template Panorama' choices:
Freedom360_3xBrodcaster_2.7K_indoor
Freedom360_3xBrodcaster_2.7K_outdoor
Freedom360_3xBrodcaster_1440_indoor
Freedom360_3xBrodcaster_1440_outdoor
AVP would not recognize the files.
olivierbo
Liked in: 134 posts
by olivierbo » Fri Apr 22, 2016 1:10 pm
Ok, but which mode are you using? 16:9 or 4:3? 16:9 should work in this case
Kind regards,
Olivier
rfendelman
by rfendelman » Fri Apr 22, 2016 1:51 pm
olivierbo wrote:Ok, but which mode are you using? 16:9 or 4:3? 16:9 should work in this case
Kind regards,
Olivier
That's the point, none of them are working for me.
olivierbo
Liked in: 134 posts
by olivierbo » Fri Apr 22, 2016 1:53 pm
Ok. Can you share your footages?
Kind regards,
Olivier
rfendelman
by rfendelman » Fri Apr 22, 2016 6:58 pm
olivierbo wrote:Ok. Can you share your footages?
Kind regards,
Olivier
I tried to send the three files as an attachment, but I doubt if you received it because they total a little over 2gb. Is there some where I can send a large file?
