Cannot Stitch correctly
Radixms
by Radixms » Tue Mar 08, 2016 10:40 pm
I have done about 10 or so other video and they have all stitch extremely well.
I am currently trying to stitch a video and it will not stitch correctly.
The sync is good if not great.
The only difference from the previous work has been that everything before this project had been recorded in 1440 using GoPro hero 3, this project was recorded with Hero 3 as well but at 2.7K.
I have started the project from scratch several times both in version 2.2 and 2.3 and tried to restitch several times once it had been stitched.
Id appreciate any suggestions.
I have uploaded a screen shot of the work space to show stitch results.
Thank You
Radixms
Re: Cannot Stitch correctly
by Radixms » Wed Mar 09, 2016 6:07 pm
Since support is not responding, I did some more searching and found that a 6 camera rig cannot be sued for 360 at 2.7k because it does not have the correct aspect ratio to properly stitch
aquabluleo
Likes: 3 posts
Liked in: 3 posts
by aquabluleo » Thu Mar 10, 2016 1:31 am
Radixms wrote:Since support is not responding, I did some more searching and found that a 6 camera rig cannot be sued for 360 at 2.7k because it does not have the correct aspect ratio to properly stitch
I use 2.7k [4:3] on gopro hero 4 ...as recommended by kolor.
Are you using the above setting?
thks
Radixms
by Radixms » Thu Mar 10, 2016 1:35 am
Hero 3 Black does not record in 2.7k 4:3 only 16:9, Ill just keep using 1440 mode.
Thanks for replying
aquabluleo
Likes: 3 posts
Liked in: 3 posts
by aquabluleo » Thu Mar 10, 2016 9:18 pm
That's right...only hero 4 ...good luck.
