Shaking problem
guruadam
Shaking problem
by guruadam » Fri Jan 08, 2016 2:42 pm
Dear Support,
I have watched all your tutorials and study all documentation but still - probably just by my another mistake - is my video - while moving with rig not stabile. Each camera is moving in slightly different direction so all 360 video then looks like shaking.
link: https://youtu.be/h6kf35-DBmI
Is this because of high RMS (3,5) ?
Is the mount not good enough?
I have tried different amount of stabilization but with same result.
Please send me any feedback.
PS: I have to use take without top camera stitch so I hope you will be fine just with logo instead.
AM
jesusrg
Re: Shaking problem
by jesusrg » Fri Jan 08, 2016 3:16 pm
I think one of your cam is not sync by 1 frame or so, or can be that is not mounted hard enough and shake independent of the rig.
guruadam
Re: Shaking problem
by guruadam » Fri Jan 08, 2016 4:29 pm
I am not sure about that, because it's happening between each one camera
guruadam
Re: Shaking problem
by guruadam » Sun Jan 10, 2016 1:33 pm
And it happened every time I have tried moving with mount. Same result, even if autopano writes that it is sync. good. But Thanks a lot for you reply! Don 't you have any other tips?
guruadam
Re: Shaking problem
by guruadam » Sun Jan 10, 2016 7:15 pm
Strange thing is that if I just don't hit compute stabilization button it's not stabile, but it's not making this jelly shaky effect...
here is video without stab. https://youtu.be/PKdKl86Rxuo
