Best GearVR 3D 360 Output   [SOLVED] - View the solution
jesusrg
by jesusrg » Sat Nov 14, 2015 9:13 pm
Hello, im want to render de best output for gearVR from autopano video pro 2, i tried 3840x1920 and autopano realoutput 38240x2160, on gearvr the video plays but in mono 360, i see both eyes, left on top and right down, with 2048x2048 output the 3d 360 looks right but i want the 4k resolution, maybe i have to change the aspect ratio from the output?, thanks.
Best regards.
Jesus.
martin.arnoux
Liked in: 27 posts
Re: Best GearVR 3D 360 Output
by martin.arnoux » Mon Nov 16, 2015 3:46 pm
It's more on the Samsung side: https://support.oculus.com/hc/en-us/art ... ulus-Video
Cheers,
Martin
jesusrg likes this post.
jesusrg
Re: Best GearVR 3D 360 Output  [SOLVED]
by jesusrg » Mon Nov 16, 2015 6:23 pm
Thanks, didnt remember that, i solve it with a "_TB" at the end of the filename.
Other question, how can i force the output of autopano video to render 3840x1920? the presets allways output to 3840x2160 and that is playing bad on gearvr, i use ffmpeg to convert it to 3840x1920 and play fine but its a reencode losing quality and more time to render. Thanks
Best regards.
Jesus
