Making Little Planet transition question
rfendelman
by rfendelman » Sat Nov 14, 2015 5:52 pm
I'm following the director cut tutorial and have made a little planet section for 5 seconds and then a transition to Spherical.
Near the end of the transition, right before I get the Spherical view, the little planet zooms in past the full Spherical view and then zooms back out to the full Spherical view.
I don't know why it's doing that. I just want a nice, easy transition from little planet into Spherical.
Any suggestions?
martin.arnoux
Liked in: 27 posts
Re: Making Little Planet transition question
by martin.arnoux » Mon Nov 16, 2015 3:48 pm
This is normal, we have to find the common point between the two projection, sometimes it means zooming a little bit. You can use little planet and fisheye which are working well together.
Cheers,
Martin
