Manual exposure compensation states after auto exposure   [SOLVED] - View the solution
pana2000
Liked in: 5 posts
by pana2000 » Sat Nov 14, 2015 6:40 am
Hi
Just getting used to the newer and excellent additions to the APV
Had no issues with adding manual stabilization points ( states ) When I tried exposure it was a bit harder
Re exposure
As per instructions ran auto exposure correction with in out sequence selected
Over the period of the 90 second clip there is still some exposure fluctuation between the start middle and end of the clip that I would like to tweak gradually over time
I have been able to apply manual adjustment points on the timeline but having trouble dragging that manual transition in the exposure timeline as is done in the stabilization Should say after the auto exposure was run the whole timeline ( in excess of the in and out point ) is now one long green transition that was automatically generated
Can manual exposure transitions be added after auto exposure correction has been calculated ?
If so how is this done
Should also say the auto exposure needs to be retained in the clip as it compensates for the variation in individual camera exposure That bit went fine Just need to adjust the overall exposure slightly over the whole clip
Thanks Lloyd
hvdarkskybd likes this post.
martin.arnoux
Liked in: 27 posts
Re: Manual exposure compensation states after auto exposure  [SOLVED]
by martin.arnoux » Mon Nov 16, 2015 3:50 pm
Auto-correction and manual correction aren't compatible in AVP. The only thing you can play with is the exposure slider for the entire panorama, after a correction.
Martin
pana2000
Liked in: 5 posts
by pana2000 » Mon Nov 16, 2015 9:15 pm
Hi Martin
That explains it
Thanks kindly Lloyd
Ps I should have posted this another week thanks for getting back
