Manual Synchronization of frames
HyperHyper
by HyperHyper » Tue Sep 22, 2015 6:35 pm
Hey everybody,
in AVP i have trouble to find the right sync. How can i manually aggust the right settings?
I would like to check an edditing software like "Adobe Priemere" , how far the frames are away from each other , how can i set the sequence for this?
Thank you for help!
olivierbo
Liked in: 134 posts
Re: Manual Synchronization of frames
by olivierbo » Wed Sep 23, 2015 12:58 pm
You will find a lot of solutions in our dedicated documentation: http://www.kolor.com/wiki-en/action/vie ... umentation
If you applied the same settings on all GoPro cameras and made an audio or motion synchronization AVP will make an accurate sync: http://www.kolor.com/wiki-en/action/vie ... ronization
Kind regards,
Olivier
talkingdog
Liked in: 3 posts
by talkingdog » Fri Oct 09, 2015 9:34 pm
I think I've mentioned before that for extreme cases I've been using Priemere's "sync audio" function. I then change the timeline to show frames and grab the frame differences and input them into autopano. It's quick and dirty but helps in a few situations.
