Black lines
Binda
Black lines
by Binda » Tue Jul 21, 2015 3:51 pm
Hi Martin,
I shot a video on 360heros Pro7 mount. After stitching in kolor pano, I am getting black lines. These lines, I assume are the gap between each camera.
How do I remove them using kolor pano?
Binda
Re: Black lines
by Binda » Wed Jul 22, 2015 8:55 am
I figured that these lines are called Nadir holes.
Request you to please reply.
Amidee
Liked in: 30 posts
Re: Black lines
by Amidee » Wed Jul 22, 2015 11:46 pm
Hi Blinda,
you seem a bit confused on how this works; this is a public forum, so you're not addressing Martin here ᗡ:
Did you set up the go pros in 4:3 (1440p, 2,7K 4:3) aspect ratio or in 16:9?
Also those are not nadir holes, they're just holes
nadir is the bottom point of your sphere, whereas the zenith is the upmost
Cliquetsy likes this post.
Binda
Re: Black lines
by Binda » Fri Jul 24, 2015 9:59 am
16:9
scottvr
Re: Black lines
by scottvr » Mon Jul 27, 2015 5:29 pm
You need to select 4:3 formats. 16:9 has less top and bottom so there's no image overlap or even image in these area to fill in.
http://freedom360.us/camera-settings/ has some good starting point and Kolor has similar guidelines.
