Frame rate problems
richtea
Frame rate problems
by richtea » Tue Jul 21, 2015 1:16 pm
After switching out a camera mid-shoot, have accidentally come back with some mismatched footage.
5 cameras are 1280x960 @ 60fps (gopro setting - ffmpeg reports 59.94)
1 camera is 1920x1440 @ 30fps (gopro setting - ffmpeg reports 29.97)
Annoying, but as it's a camera that mostly faces a wall, I figured doubled frames wouldn't be the end of the world.
So I did
ffmpeg -i input.mp4 -vf "fps=59.94,scale=1280:960" -c:a copy -c:v "libx264" -crf 0 output.mp4
Now ffprobe reports all the videos as the same frame rate and resolution, but autopano video pro still says
'All video files must have the same framerate'
Any ideas/insight into how autopano determines a mismatch that I can use to work out what is going wrong?
Amidee
Liked in: 30 posts
Re: Frame rate problems
by Amidee » Tue Jul 21, 2015 2:55 pm
try doing that for the other 5 cameras, too ( :
richtea
by richtea » Tue Jul 21, 2015 5:31 pm
Tried a variation on that - re-concatenated all of the other source files using the ffmpeg concat protocol rather than the ffmpeg concat demuxer and the problem went away.
