Nadir patching
onespoon
Nadir patching
by onespoon » Mon Jun 29, 2015 6:37 pm
Hi, I'm trying to patch the nadir of a 360 video in Autopano Pro 4.0 as it says on http://www.kolor.com/wiki-en/action/vie ... r_patching But the image I added is blended with the layers. How do I turn off the blended layer. I've tried rename the layer, but it doesn't work. Anyone can help? Thanks!
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Nadir patching
by Cliquetsy » Mon Jun 29, 2015 6:46 pm
Could you show us a screenshot of the panorama editor window (where you added the patch), and perhaps the patch you've used?
Did you activate quick preview?
onespoon
Re: Nadir patching
by onespoon » Mon Jun 29, 2015 7:30 pm
Attache the screen shot of the problem, it appears to be transparent and distorted. Thank you for your help.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Nadir patching
by Cliquetsy » Mon Jun 29, 2015 8:12 pm
onespoon wrote:Attache the screen shot of the problem, it appears to be transparent and distorted. Thank you for your help.
You haven't activated quick preview.
You can tell if it's activated or not because your panorama will have a green outline/border when it is.
onespoon
Re: Nadir patching
by onespoon » Tue Jun 30, 2015 3:09 am
The logo gets even more transparent when I activated the preview. Any idea? Something I did wrong?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Nadir patching
by Cliquetsy » Tue Jun 30, 2015 7:28 am
The layer has to be called "patch".
Re: Nadir patching
by Annis » Tue Jun 30, 2015 8:51 am
The layer has to be called "patch" (not case sensitive), but there mustn't be any other variation in the name.
- Patch that works
- Patch that won't work
Once you've renamed the layer, uncheck the layer's visibility then check it again to refresh it.
onespoon
Re: Nadir patching
by onespoon » Tue Jun 30, 2015 9:19 am
It works! Thanks so much! :)
Annis likes this post.
onespoon
Re: Nadir patching
by onespoon » Tue Jun 30, 2015 9:55 am
I did a test, the 360 video was shot on foot walking up stairs, the patch logo is swinging like the movement of the walking. Any idea I can make the patch logo fixed on one spot without attaching to the movement of the camera?
Amidee
Liked in: 30 posts
Re: Nadir patching
by Amidee » Thu Jul 02, 2015 10:27 am
you must have used motion compensation; it's correct this way, otherwise you would have the patch staying fixed and the hole (or whatever you're covering, is that a tripod?) underneath it moving around (:
