AVP 2 b2 - download problems   [SOLVED] - View the solution
by gkaefer » Fri Dec 19, 2014 4:50 pm
since 2 hours I try to download the AVP 2 b2 64bit for Windows.
the dowloads Interrupt or after downlowd "succeeds" I get following screenshot:
Re: AVP 2 b2 - download problems
by Annis » Fri Dec 19, 2014 5:03 pm
Could you try the solutions on this page: http://nsis.sourceforge.net/Why_do_I_get_NSIS_Error
If they don't work, tell me precisely which version you want and I'll send you the installer via WeTransfer (and by PM send me an e-mail to send it to...).
DrSlony
by DrSlony » Fri Dec 19, 2014 5:08 pm
Also try clearing your web browser's cache (and your proxy's cache, if you use one).
by gkaefer » Fri Dec 19, 2014 6:08 pm
Firefox no prob.... IE11 I do get the prob. Cach cleared... no Change.
...nsis error... to make it shot all12 possible Solutions provided do no Count....
I start the download and after around 7MB the download stops/halts with Option to resume. this than Fails or it succeeds which later gives me the nsis error. Clearing Cache, deleting donwloaded artefacts etc all does not work for IE11.
PS the beta 1 I could download as the other Versions before with the IE11...
(also other Downloads now work for the IE11....)
Firefox succeded... who cares about IE...
by AlexandreJ » Tue Dec 30, 2014 9:23 am
We changed a bit the download system for our softwares. It does now support resume.
Normally, it will eliminate most of the corrupted archives.
