[SOLVED] How to select the graphiccard for rendering?   [SOLVED] - View the solution
monsterframes
by monsterframes » Sat Oct 04, 2014 11:11 am
Hello!
First of all: i have screenshots. :cool:
My Problem: I have a Lenovo T430 in the highest configuration. There are 2 graphiccards/chips in it.. A Nvidia Graphiccard and the onboard chip for saving power.
When i start the application normaly, its rendering with the intel onboard card.
Finaly i found a mode, to start the application over the nvidiacard
its working, the application starts and give me the card in the settings
Now the problem:
When i start the application over Nvidia, i can drop one video. After i drop more then one video, its freezing. Even if i wait a lot of time, its not more working. So i try to open a project, that i create by a normal start - but thats not working too. I looks like he can render the preview just for one video.
I cant upload more then 3 screenshots so i put it in the next post.
I tryd that with 1.6.3 and 1.7.0 RC1. Maybe its because, the whole application runs over the graphiccard from nvidia, when i chose this. Maybe its better to start it normaly,.. and chose then the graphiccard to render it.
Is this actualy possible?
Thanks and sorry for my english!
Martin
monsterframes
Re: How to select the graphiccard for rendering?
by monsterframes » Sat Oct 04, 2014 11:12 am
Freeze, looks like he cant render the preview then for more then one video:
monsterframes
by monsterframes » Sat Oct 04, 2014 11:30 am
Note:
I tryd this:
viewtopic.php?f=48&t=23559 / But i cant select any autopano application in the manager. :(
martin.arnoux
Liked in: 27 posts
by martin.arnoux » Mon Oct 06, 2014 9:40 am
You were right, you just need to add Autopano Video executable file "C:\Program Files\Kolor\Autopano Video Pro 1.x\AutopanoVideoPro_x64.exe" into the Nvidia Control Panel. Once it's done you can select which GPU you want to use for this app.
Let me know if it helps,
Martin
monsterframes
by monsterframes » Mon Oct 06, 2014 7:33 pm
Now i see the nvidia card in the settings, but this problem with the nvidia anyway:
monsterframes wrote:Freeze, looks like he cant render the preview then for more then one video:
captain3d
by captain3d » Mon Oct 06, 2014 8:11 pm
Are the movies and unusual size? Dimensions should divide by 4. I have had similar problems.
phil
monsterframes
by monsterframes » Mon Oct 06, 2014 8:17 pm
captain3d wrote:Are the movies and unusual size? Dimensions should divide by 4. I have had similar problems.
they are 1920*1440 :)
monsterframes
by monsterframes » Sat Oct 11, 2014 2:19 pm
Nobody can help :(?
Joergen Geerds
Re: How to select the graphiccard for rendering?  [SOLVED]
by Joergen Geerds » Tue Oct 14, 2014 2:33 pm
This may be a codec problem with windows: download and install a windows codec pack (i.e. http://www.free-codecs.com/download/K_L ... c_Pack.htm). restart, and see if the problem persists.
captain3d
by captain3d » Tue Oct 14, 2014 6:31 pm
Are they mp4 movies or something lossless?
Kolor does not handle none Mp4 movies very well if GPU is on. Turn off GPU and restart to see if it works (slowly of course)
phil
monsterframes
by monsterframes » Sun Oct 19, 2014 2:22 pm
It was the codecproblem.
Thanks! :)
