seam question
Becky
seam question
by Becky » Wed Jul 09, 2014 7:22 am
Hi Everybody,
I am a new 360 videos user.
I use freedom 360 with Gopro Hero3 Black to shoot video,
and camera setting: 1080P at 30fps (16:9).
I stitch them with Autopano Video with "Stitch as GoPro",
and edit the reference pano in Autopano with control points by myself,
But still some "seam" can't remove.
how can I do? or need to change the camera setting?
thank you!
jasonfletcher
Liked in: 5 posts
Re: seam question
by jasonfletcher » Fri Jul 11, 2014 6:21 pm
I think this video will help you understand how to best remove seams.
http://www.autopano.net/wiki-en/action/ ... foreground
Or the case might be that you are experiencing parallax. If any object gets too close to the camera rig then this is unavoidable.
http://www.autopano.net/wiki-en/action/ ... -_Parallax
Jason Fletcher
Science Visualizer
Charles Hayden Planetarium
http://www.thefulldomeblog.com
jasonfletcher
Liked in: 5 posts
Re: seam question
by jasonfletcher » Fri Jul 11, 2014 6:52 pm
Also, this forum post might be helpful for you.
viewtopic.php?f=47&t=22866#p145595
Jason Fletcher
Science Visualizer
Becky
Re: seam question
by Becky » Thu Jul 17, 2014 4:15 am
Thank you very much!! I will try it, it is very helpful for me!!
Joergen Geerds
Re: seam question
by Joergen Geerds » Fri Jul 18, 2014 1:22 pm
If you are using the Freedom360 mount, you need to switch the cameras to the 1440 wide or 960 wide mode: shooting in 1080 doesn't work, and using the "1080 super view" is also not ideal.
