Export video as multiple layers?
captain3d
by captain3d » Wed Jun 25, 2014 5:19 pm
Hi
Autopano Giga allows the export of a photoshop layer file. So the individual pictures can be worked on further. I would like to do the same in After effects for video.
Is there a way to output each stitch element as its own video with an alpha?
phil
Re: Export video as multiple layers?
by AlexandreJ » Fri Jun 27, 2014 1:36 pm
We had this idea several months ago, but there is an issue with video, only a few encoding format in video supports alpha channel.
For the moment, one trick:
- go to layer editor in autopano
- uncheck all video except one
- in AVP, render
Repeat that for all tracks.
angutir likes this post.
captain3d
by captain3d » Fri Jun 27, 2014 8:28 pm
Thanks for the tip. It works for my purposes.
phil
angutir
by angutir » Wed Apr 06, 2016 11:16 pm
It will be a good idea if we can change the background color from autopano video renders to mask it more easy, the black color it is not a good color for masking.
