[SOLVED] APP - AVP interaction
odendaal
by odendaal » Mon Apr 07, 2014 3:38 pm
I generate a panorama in Autopano Video Pro 1.1. I then select to edit it in Autopano Pro 2.6. The Panorama in Autopano Video Pro looks fine. But Autopano Pro does not show the panorama in it's preview window. There is simply a grey - and sometimes white - screen. Why might this be?
Liked in: 442 posts
Re: Autopano Pro - Autopano Pro Video interaction
by Annis » Mon Apr 07, 2014 3:51 pm
To use Autopano video, you need Autopano Pro/Giga 3 minimum.
To use Autopano video 1.5+, you need Autopano Pro/Giga 3.5+ minimum.
odendaal
by odendaal » Thu Apr 10, 2014 7:27 am
I am working with Autopano Video Pro 1.1 and Autopano Pro 2.6. According to your previous message, these two should be compatible, right?
Liked in: 442 posts
by Annis » Thu Apr 10, 2014 8:21 am
odendaal wrote:I am working with Autopano Video Pro 1.1 and Autopano Pro 2.6. According to your previous message, these two should be compatible, right?
Unfortunately, no, it's Autopano Pro 3 minimum, as stated in my previous message.
