Read this before posting - Forum rules
by Annis » Thu Mar 27, 2014 4:54 pm
This sub-forum is for users looking for a better way to solve a specific case of stitching videos, or just looking for basic instructions.
Do not post any bug reports, stability issues, crash reports, etc. - use the Bug Report forum for those.
Before asking for technical support, have a look at our Documentation and Video tutorials.
When posting, make sure that you provide as much informations as possible, so that the problem can be identified quickly, and solved swiftly:
- Your computer specs (OS and OS version, GPU model, GPU driver version, ...)
- Which software you are using (AVP/AVP Pro) and its precise version (if its a beta, tell us which one)
- What setup are you using:
- How many cameras and their models
- What are the input AND output format (A/V codecs and file format used)
- Screenshots, we love those
- etc..
Once the issue is solved, please check the solved button on the top right corner of the post that provided you with the solution.
Thanks for reading.
