Control Points Optimization Settings - AVP 1.5 Beta 3
jasonfletcher
Liked in: 5 posts
by jasonfletcher » Tue Mar 11, 2014 10:28 pm
I just realized that the Control Points Optimization Settings has received an update. But I can't find where the Lens Distortion Correction Options have moved to.
--- Have they been rolled into the Optimization Scopes submenu?
--- If so, how can I replicate these settings to improve GoPro stiching settings? (source)
Jason Fletcher
Science Visualizer
Charles Hayden Planetarium
http://www.thefulldomeblog.com
ThomasV
Re: Control Points Optimization Settings - AVP 1.5 Beta 3
by ThomasV » Thu Mar 13, 2014 9:12 am
Yes, the control point editor changed in the 3.5 version.
The Lens distortion parameters have moved in the 'Optimization scopes' submenu as you guessed.
Concerning the settings you want to apply, ie:
- Identical focal
- Force different distortion
- 3rd order distortion model + optical center,
it translates to :
- Focal         : Automatic  -- Scope : pano (all images of the pano will have the same focal value)
- Distortion   : 3rd order  -- Scope : image (each image will have its own distortion values)
- Offset        : Enable      -- Scope : image (optical center will be optimized for each image)
Documention will be updated soon.
Regards,
Thomas
jasonfletcher
Liked in: 5 posts
by jasonfletcher » Thu Mar 13, 2014 3:07 pm
Thanks for the quick update. I enjoy the new Control Points Optimization settings layout.
I believe I got the settings correct. Can you confirm? Screenshot below.
--- Also is this setting correct? = Viewpoint: Enable for some images
--- http://i.imgur.com/gKFNCuv.png
Its so helpful to hear directly from the Kolor team directly. Many thanks!
Jason Fletcher
Science Visualizer
Users browsing this forum: Yahoo [Bot] and 1 guest
