360Heros H3Pro7 - Stitching Template
Hellkeeper
by Hellkeeper » Fri Sep 13, 2013 1:55 pm
someone got a "perfect" stitching Template for 360Heros H3Pro7? Didn't found one from Kolor directly?
Thank you
Andreas Schnederle-Wagner
Gigapixel Panos from Austria: gpix.at
by AlexandreJ » Mon Sep 16, 2013 12:18 pm
It is not possible to create a perfect stitching template as you are not at the nodal point. So the template will always depend on the content.
We have a page with some template here but we need to complete it for sure with the H3Pro7 : http://www.autopano.net/wiki-en/action/view/Autopano_Video_-_Template_Stitching
yves360
Re: 360Heros H3Pro7 - Stitching Template
by yves360 » Sat Jan 25, 2014 11:39 pm
is there any news about templates for the H3Pro7?
Thank you ;-)
jeffouille
by jeffouille » Thu Apr 03, 2014 8:53 am
Any news ?
searching templates for H3PRO7 and H3PRO7HD
jasonfletcher
Liked in: 5 posts
by jasonfletcher » Thu Apr 03, 2014 10:16 pm
Using a template is not going to improve your stitch, in fact it will probably make it the parallax seams even more visible.
Autopano Video uses the overlapping content between each video to automatically create a 360° projection. So in a way, each time you import all the videos, synchronize, and stitch; you are effectively creating a custom template that is optimized to that individual shot and its specific parallax errors.
Due to the unavoidable parallax errors, you will get a much better result if you do not use a pre-made template. There is no such thing as the "perfect" template, since all of the camera sensors are not at the same nodal point.
Pre-made templates are especially ineffective now that in AV 3.5, you can interpolate between different stitches.
If you are having problems with AV recognizing one of your channels, make sure you are selecting a good frame in the timeline as your initial stitch. But occasionally a shot pointing straight up at a blue sky will not automatically be placed for stitching and must be placed manually.
Jason Fletcher
Science Visualizer
Charles Hayden Planetarium
http://www.thefulldomeblog.com
