Output video size
kclai
Output video size
by kclai » Mon May 20, 2013 4:36 am
another question about the output video size. According to the software feature page, it can support any output size. However, in the setting->encoding preset, I could only choose from the preset ranged from 320x240 to 4096x2048. Is that any way to create new preset? thx
regards,
KC
by AlexandreJ » Wed May 22, 2013 12:19 pm
Encoding Presets are here to help you get certain size directly. We have all standard preset below fullHD and we created our own h264 preset for 4K rendering ( which is not in the specification of H264, but it works quite well in our case ). Question: Would you be interested into H265/HEVC encoding which support officially 4K with half the size of H264 ?
Above 4K, there are no video codec that we know of that support such size, so, if you need such size, just select frame output and each frame will have the maximum size.
If you are missing some preset, just ask, we can add them.
by klausesser » Wed May 22, 2013 12:44 pm
kclai wrote:Hi,
regards,
KC
How would you display more than 4k actually?
by gkaefer » Wed May 22, 2013 9:46 pm
klausesser wrote:
kclai wrote:Hi,
regards,
KC
well, some Demos may already be available...
http://www.golem.de/news/pansonic-riesiges-plasma-display-beeindruckt-mit-8k-aufloesung-1208-94190.html
and if i take the size of 7.680 à— 4.320 Pixeln (8K) ... if uses as partial pano you can use better Quality in your more than 8K sized still pano (tour...)
:cool:
