multiple reference image
kclai
by kclai » Fri May 17, 2013 10:30 am
I discover the system accept multiple reference at the bottom box. Is it possible to use different stitching reference for different section in the footage? The distance to object may be varying with time and we may want to treat them separately. Thx
Regards,
KC
by gkaefer » Fri May 17, 2013 10:55 am
kclai wrote:Hi,
Regards,
KC
I do interprete the docu exact in this way. so multiple reference panos are possible to reflect different onscene Locations (changing indoor/outdoor in the Video, street<->tunnel, any possible distance Change to the object in mainfocus of the Scene as you did write...
see "Creating and editing the reference panorama ": http://www.autopano.net/wiki-en/action/view/Autopano_Video_-_Workflow
by AlexandreJ » Fri May 17, 2013 10:57 am
Yes, you can have several reference and for each reference, decide to render only a part of the timeline.
It is then up to you to glue every rendering together.
Of course, the idea behind is to offer you a real timelime, with keypoint, etc.
kclai
by kclai » Fri May 17, 2013 2:13 pm
AlexandreJ wrote:Yes, you can have several reference and for each reference, decide to render only a part of the timeline.
Hi Alex,
Can you tell more about how to do it? The doc didn't talk much about it, thx
-- update:
I tried to hit "Stitch as Gopro" when the time slider was set to another position, a new ref TIF set was generated at the side of the first ref image, but it seems like the new ref was being ignored when I render the video. What should I do if I want the extra ref be effective?
Regards,
KC
