What's about....
Support on the Panoshoot device
Markus W.
Likes: 8 posts
What's about....
by Markus W. » Thu Nov 07, 2013 2:26 pm
new Firmwareupdates? The last Update was in May 2013.... :rolleyes:
guchtpi
Re: What's about....
by guchtpi » Fri Nov 08, 2013 9:09 am
Same question from my side !
I've also asked about the availability of the API documentation/description...
And no answer *EVER* from anyone at "panoshoot.com".
This is not serious !
100lux
by 100lux » Mon Nov 11, 2013 4:03 pm
same here...
whats up with you ???no firmware update since have a year...
shais
Liked in: 3 posts
by shais » Tue Nov 12, 2013 9:13 pm
Same here! Can someone tell if these guys still exist?
No replies on anything, no comments, no support (Even a reply like "we are aware of this or that problem and are working on a solution" is better than no reply at all)
by mediavets » Tue Nov 12, 2013 9:32 pm
shais wrote:Same here! Can someone tell if these guys still exist?
I believe this forum member is one of the Panoshoot guys...you might try a PM?
memberlist.php?mode=viewprofile&u=68058
javqui
by javqui » Wed Nov 13, 2013 3:04 am
Hi
We are active. I was working the last months in one project related in some way with Panoshoot.
The project is really intense, Monday to Monday dedication. I will have a "temporal vacation" from this project the next two weeks, so I will be able to include some improvements and release a new update.
Markus W.
Likes: 8 posts
by Markus W. » Thu Nov 28, 2013 7:19 pm
javqui wrote:Hi
Two weeks are over... any informations about a new and working update?
Markus W.
Likes: 8 posts
by Markus W. » Thu Dec 05, 2013 7:51 pm
NO BUGFIXES, nothing happend since May. I want my Money back!
I will contact the Guy's from Kolor, because I am disappointed and very angry about this behavior!
shais
Liked in: 3 posts
by shais » Fri Dec 06, 2013 7:15 am
I've got an email from panoshoot regarding a specific problem I have with the mirror lock-up. They said that a new firmware update will be announced soon. But I must say that sadly this is not the only problem I have. I had a big and expensive shooting day and the XMLs are useless. I'm now stiching hundreds of sky frames by hand.
I'm still not giving up on this though. First, because I think that this product has good potential, and second because I have no other way to control the head.
Do you have another controller?
claudevh
by claudevh » Fri Dec 06, 2013 9:34 am
Alternatives exists :
Papywizard (multiplatform), PandroidWiz (Android) and T&C touch-controler (full autonomous controler device)
T&C Touch Controler:
http://www.typeandcolour.de/index.php?ln=en&tp=hhc_home
http://magasin.skivr.com/en/accessoires-panogear/152-touch-controler-for-panogear-merlin-head.html
PandroidWiz:
Android application for Merlin head. (free you just need a BT module for the Merlin head and a Tablet or simple smartphone...
https://play.google.com/store/apps/details?id=com.fvh.panoramic.pandroidwiz
And of course ...
Papywizard see in the present forum.
Good luck
by klausesser » Fri Dec 06, 2013 2:18 pm
You can give me some details - sensorsize, focallength, overlap. I guess you shot spheres!?
I will use the T&C handheld to generate the xmls for you. It´s a very reliably and perfectly working device . .
shais
Liked in: 3 posts
by shais » Sun Dec 08, 2013 4:40 pm
Thank you!
I have already done most by hand, but I have one left and it's in a mess, so this might really help!
sensor is 35.9 × 24 mm, focal length is 105mm, minimum overlap 27% and I shot 270X180 deg.
the head was mounted upside down if it matters.
Thank you!
Shai
by klausesser » Sun Dec 08, 2013 5:03 pm
shais wrote:Thank you!
Hi!
What does "minimum overlap 27%" mean exactly? Overlap *needs* to be constant!
What does "the head was mounted upside down" mean exactly?
If you ever do the same thing again: shoot full spheres!
shais
Liked in: 3 posts
by shais » Sun Dec 08, 2013 5:11 pm
the minimum overlap is just how it is set up with panoshoot. the exact overlap is
27% horizontal 31.3% vertical
and the head mount is like this:
by klausesser » Sun Dec 08, 2013 5:19 pm
shais wrote:the minimum overlap is just how it is set up with panoshoot. the exact overlap is
How many shots? My head calculates 348.
by mediavets » Sun Dec 08, 2013 5:40 pm
shais wrote:I have already done most by hand, but I have one left and it's in a mess, so this might really help!
Thank you!
Shai
I'll have a go at creating an XML file using Papywizard in simulation mode...
So was this a regular grid/matrix/mosaic of images? That is same number of shoits in every row.
If so how many rows and columns?
What was teh shooting order row by row or column by column?
Did you start top left or at some other corner?
Did you return to the start of each row or column or reverse direction for alternate rows or columns?
Do yoiu have fullframe or a cropped sensor body?
If cropped sensor what is the crop factor (or which brand/model of camera?)
by klausesser » Sun Dec 08, 2013 5:52 pm
here´s the XML: (i couldn´t mount the head upside-down - so you need to turn the images 180°)
www.360impressions.de/Shai.zip
by klausesser » Sun Dec 08, 2013 5:56 pm
Thank you!
Shai
Hi Andrew!
1) he shot an angle-mode of 270x180°
2) his camera is a D800 - so he has 35.9 × 24 mm.
How far rows and columns are identical with the PW pattern - we´ll see . . :cool:
Of course there´s the problem where he started - but he might be able to set that in the stitch
by using the centerpoint . . Just an experiment.
Funny thing to try anyway. I suggested to shoot always full spheres in such situations.
by klausesser » Sun Dec 08, 2013 6:15 pm
Shais -
do you have XML files at all from this shooting??
by mediavets » Sun Dec 08, 2013 6:17 pm
klausesser wrote:Hi Andrew!
I need to know the shooting pattern for a Papywizard created XML to have a chance of working.
by klausesser » Sun Dec 08, 2013 6:30 pm
because he didn´t shoot a full sphere there´s much unlikely a chance to match his pattern - we don´t know
where exactly he started . . .
I don´t know much about how far the Panoshoot uses a PW kind of pattern at all . .
P.S.: i mean it´s unacceptable how Panoshoot lets it´s clients hang out allone with their issues.
shais
Liked in: 3 posts
by shais » Sun Dec 08, 2013 6:53 pm
Hi guys,
thank you so much for this.
Does this timelapse video help?
https://www.dropbox.com/s/zorzqekvxytax0h/Shooting.mp4
by klausesser » Sun Dec 08, 2013 7:12 pm
shais wrote:Hi guys,
ok - it´s zig-zag. Row by row. Maybe it works with the PW pattern.
But the problem is: IF you would have used a full sphere there´s no beginning and no end - this way it´s easy to make a virtual pattern externally.
You shot a certain angle - this way you need to find out where you started and where you stoped shooting.
I nevertheless suggest to use my xml to see what happens.
Again: don´t you have any xml from your Panoshoot?
by mediavets » Sun Dec 08, 2013 9:16 pm
Yes.
Appears to start top left and reverse at end or row?
But I need to know how many rows and columns of images were shot. That is say X rows of Y images.
Also did you bracket exposures or was there only one image per shooting position?
by klausesser » Tue Dec 10, 2013 12:39 pm
Yes.
Not necessarily. The rows and columns result from the values of the angle and the focal length.
This values he told precisely - i hope :cool: - 270x180°
It´s worth a try anyway, i mean. The problem is to find the point where the shooting started.
That´s why i suggested to always shoot a full sphere - whether you need all images or not.
mediavets wrote:Also did you bracket exposures or was there only one image per shooting position?
If he´s going to try my XML: it´s set to record ONE exposure on each location. I can change that -
but i prefer it this way because i always process bracketed shots before stitching.
PS: he shot 14 rows as i counted . . :cool: knowing sensorsize and overlap it´s easy to calculate
the shots per row and find the amount of columns. (can be found in my xml btw.)
PS2: PapyWizard calculates 364 shots, my handheld calculates 348 shots - using a different head of course.
I´ll post the XML from the PW-simulation too.
