Changed a setting and now I can't open config
Support on the Panoshoot device
shais
by shais » Mon Oct 28, 2013 12:31 pm
I turned on the sound option in the config in panoshoot.
Now I can't open the settings again and the screen is stuck on the "run session" screen.
The joystick still works though
I don't know if it has anything to do with the setting I changed.
I'm connected directly to panoshoot with windows\chrome
Any help?
Thanks,
Shai
shais
Re: Changed a setting and now I can't open config
by shais » Mon Oct 28, 2013 12:42 pm
I tried now to open it in explorer and it seems to work!
panoramicessentials.com
by panoramicessentials.com » Thu Oct 31, 2013 8:10 am
shais wrote:I tried now to open it in explorer and it seems to work!
Glad to hear that you figured it out.
Return to Panoshoot
