WI FI undefined error
Support on the Panoshoot device
tws7
by tws7 » Tue May 14, 2013 4:13 pm
When I try to connect to my home router all I get is "undefined". When I try to connect my Neighbors wi fi there is no problem and I've reset the router so what am I doing wrong?
Markus W.
Likes: 8 posts
by Markus W. » Tue May 14, 2013 5:02 pm
Check the distance to your wireless network. The same happens to me, if the distance is to wide to my router.
javqui
by javqui » Tue May 14, 2013 5:18 pm
Thank Marks, for the help.
I will complement the answer with an additional suggestion.
Install the WiFi analyzer.
It will not only help to fix the issue, but it could help to improve your own WiFi network. Particularly useful if you watch videos or use other type of stream services, like internet radio/music, youtube, movies, etc.
a a gruntpuddock
by a a gruntpuddock » Tue May 14, 2013 10:19 pm
I found this free program useful - http://www.metageek.net/products/inssider/
tws7
by tws7 » Sun May 19, 2013 1:36 am
I got it to connect to the internet by temporary turning off the security on my router, Brute force but it worked
