professional tools
About the allview mount
gabrielefx
professional tools
by gabrielefx » Mon Mar 10, 2014 5:26 pm
Hi all,
I'm entering now in this pano world and I want to do it professionally buying the right software and hardware.
I do 3D panoramas using virtual renders not photos.
I want to integrate and match 3d virtual objects with real photos.
Panotour Pro is an excellent software and probably I will buy the stitching tool.
I would like to ask you the follow questions:
I want to buy a fast and precise motorized head, do you think that the Seitz VR Roundshot drive is good enough?
or
Is it better to buy a rig with 6 GoPro 3+?
I don't want to shot videos, I'm interested in the best quality possible (not giga photo). I got several Sony Zeiss lenses.
There is an issue with moving people shooting panoramas. How to fix it?
Do you suggest one shot head and 3 camera bodies?
What's the best solution?
I read about a product: PTGrey Ladybug 5. Worth it?
thank you for your answers.
regards
edit: please move this post it in "hardware". Sorry.
Re: professional tools
by mediavets » Mon Mar 10, 2014 7:26 pm
gabrielefx wrote:I want to buy a fast and precise motorized head, do you think that the Seitz VR Roundshot drive is good enough?
Yes.
Or look at the Panoneed:
http://www.panoneed.com/
http://www.typeandcolour.de/index.php?ln=en&tp=pk_home
Or Dr Clauss Rodeon:
http://www.dr-clauss.de/en/foto-studiot ... ead-series
What camera body do you plan to use?
And lenses?
gabrielefx
by gabrielefx » Mon Mar 10, 2014 8:09 pm
thank you,
I got an Alpha 55 with some Zeiss lenses: 16-24, 24-70, 85, 135
For moving people probably I need a fisheye but I loose in quality.
by klausesser » Mon Mar 10, 2014 8:20 pm
gabrielefx wrote:For moving people probably I need a fisheye but I loose in quality.
You loose resolution using a fisheye. But you definitely win when shooting cowded places . . :cool:
You also can use non-fisheyes . . . but be prepared to need MASSIVE editing.
If you decide to buy a fisheye for shooting in crowded places: better use a manual head and use the saved money to buy a good
fisheye-lens.
