Shutter release with the AllView
About the allview mount
kosmarnik
by kosmarnik » Sun Aug 26, 2012 1:31 am
The shutter release jack on the AllView. I can't get it to work with my wireless triggers.
I got the right cable (PC->2.5 mm mono TRS connector) and it'll fire as soon as it's shorted.
AllView goes to the motions of shooting, but doesn't release the trigger.
It states that it's Canon compatible, so maybe it's not shorting the connection, but doing something else. I have no clue and no Canon DSLRs at hand.
Any ideas?
Likes: 4 posts
Liked in: 59 posts
by klausesser » Sun Aug 26, 2012 12:44 pm
kosmarnik wrote:The shutter release jack on the AllView. I can't get it to work with my wireless triggers.
Any ideas?
I guess you need a stereo-jack. 1. half press for measuring and 2. full press for release.
kosmarnik
by kosmarnik » Sun Aug 26, 2012 9:53 pm
Any ideas?
Might be, but don't have one at hand. I did try with a 4 pole 2.5mm jack, and a multi-meter, doesn't short the tip :|
Seems like the plug is mono as the other poles are shorted as soon as I plug it in.
I'm guessing theres something wrong with my port.
Oh joy.
Pinout is pretty simple: http://www.doc-diy.net/photo/remote_pinout/
RobSherratt
by RobSherratt » Thu Oct 25, 2012 1:27 pm
Any ideas?
My AllView was delivered with a shutter release cable comprising a 2.5 mm TRS / stereo plug at each end. It is wired T-T R-R and S-S. No crossover. It works perfectly with my Canon EOS 500D.
I am confused because you say you have a cable with a mono TRS connector. This is a contradiction in terms. A mono 2.5 mm plug is TS only and will not work.
Note: TRS = Tip Ring Shield, a legacy description stemming from the days of manual switchboards (pre-strowger) where 1/4 inch connectors with three contacts were used to connect the Tip, Ring and Shield signals to and from telephone customers.
Rob Sherratt, British ex-pat living in Corfu, Greece
Professional Engineer; Amateur Musician, Photographer and Motorcyclist; Novice Moderator for this part of Kolor Forum!
"If all life's a stage, how come I can't remember my lines?"
