Neutralhazer and Photoshop Elements 14   [SOLVED] - View the solution
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
doowopper
by doowopper » Sun Sep 27, 2015 3:24 pm
I purchased Neutralhazer from Kolor in 2013 and have been using it in a Windows 7, 32 bit computer within Photoshop Elements 10. Today I purchased Photoshop Elements 14 and I am using Photoshop Elements 14 in the same computer.
1) Can I install the Neutralhazer I purchased in 2013 into Photoshop elements 14?
2) If so how do I do it?
Thanks.
Richard
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Neutralhazer and Photoshop Elements 14  [SOLVED]
by Cliquetsy » Sun Sep 27, 2015 3:57 pm
You'll have to install it manually, but you can use it:
http://www.kolor.com/wiki-en/action/vie ... options.29
If Photoshop Elements 14 is anything like v13, then you have to activate the settings to use external plugins (also explained on the page)
