Installing on Photoshop 2015   [SOLVED] - View the solution
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
msr
by msr » Sun Aug 30, 2015 12:25 am
The plug-in did not carry over from CC 2014. This company does not understand support. Does any one know how to install the neutralhazer on CC2015
Re: Installing on Photoshop 2015
by Destiny » Sun Aug 30, 2015 3:43 am
Hi.. Sorry I don't... I have wondered for a long time how Third Party Plugins work with Cloud based software.... since you don't atually have the software installed on your system....
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Installing on Photoshop 2015  [SOLVED]
by Cliquetsy » Mon Aug 31, 2015 1:43 pm
http://www.kolor.com/wiki-en/action/vie ... options.29
"Manual installation is required for any Photoshop version above and including CS5, Photoshop CC, and Photoshop Elements 10."
