Gray Photo After Processing   [SOLVED] - View the solution
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
Runnerduck
by Runnerduck » Tue Aug 19, 2014 11:52 pm
I'm running the demo software in Photoshop CC 2014. When I Export it comes into Photoshop and has a faint gray outline of my photo. It also has a big red X of "KOLOR" across the photo which is what I'd expect from the demo copy.
How do I get the photo I modified back into Photoshop?
This is the results
Runnerduck
Re: Gray Photo After Processing
by Runnerduck » Tue Aug 19, 2014 11:54 pm
Woops, I forgot to check "email notification" when I posted this question.
Re: Gray Photo After Processing  [SOLVED]
by Annis » Fri Aug 22, 2014 9:58 am
The result you are getting is because you must have checked "Export" for the Haze map. If you un-check this option, the haze map won't be exported over your image.
