[SOLVED] Photoshop Elements 12   [SOLVED] - View the solution
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
JerryP
by JerryP » Sun May 04, 2014 5:14 pm
Hi everyone,
Does anyone know if Neutralhazer works with Elements 12?
Thanks in advance,
JerryP =D
Re: Photoshop Elements 12
by mediavets » Sun May 04, 2014 5:22 pm
JerryP wrote:Hi everyone,
Thanks in advance,
JerryP =D
The FAQ suggests that it is not:
http://www.kolor.com/neutralhazer-haze- ... n-faq.html
Liked in: 440 posts
by Annis » Mon May 05, 2014 10:11 am
Neutralhazer requires manual installation for Photoshop versions above CS5 and Elements 10 (procedure for mac | procedure for windows).
Make sure you keep to the set file hierarchy or the filter will not work correctly.
JerryP
by JerryP » Mon May 05, 2014 10:19 am
Thank you both for the advice. I think I'll try the manual install...I am keen to use it in Photoshop.
JerryP
JerryP
by JerryP » Mon May 05, 2014 1:57 pm
I've carried out a manual install of the plugin, but do not see it in Elements. I had to create the Filters / Kolor folders within the Plug-Ins folder, is there anything else I need to do to get Elements to see the files?
Many thanks,
JerryP
Liked in: 440 posts
by Annis » Mon May 05, 2014 3:02 pm
No that should be it, could you post a screenshot of the file path you put the plugin in?
Are you on a Mac or PC? If you're on a PC, 32bits or 64bits?
JerryP
by JerryP » Mon May 05, 2014 3:26 pm
Screenshot of Neutralhazer directory structure
Here it is...
Any help would be most appreciated.
Thanks,
JerryP
by JerryP » Mon May 05, 2014 3:33 pm
Should all the .dll files be in the same folder? None of the other plugins seem to have any, and there are a significant number in the top level 'Photoshop Elements 12' folder. (I'm guessing now!)
JP.
JerryP
Re: Photoshop Elements 12  [SOLVED]
by JerryP » Mon May 05, 2014 3:49 pm
Hi.
I'm sorted - I'd got it all wrong...I always believed that the folder 'Program Files (x86)' was 64 bit - it's not, it's 32 bit. Having installed the 32 bit version, everything is up an running.
Sorry to have wasted peoples' time, still I've learnt something!
Apologies,
JerryP :rolleyes:
Liked in: 440 posts
by Annis » Mon May 05, 2014 4:03 pm
Glad that was sorted then. I hadn't had the time to give you an answer yet.
