Neutralhazer and big files ... old problem ... no solution so far ...
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
PeterE.
by PeterE. » Sun Aug 18, 2013 1:42 pm
I use PS5x64 on Windows 7-64 with a Core i7 8 GB computer. When I try to process a 30000 x 8000 16 bit image Neutralhazer will abort PS5 when the progress bar reaches about 55 to 60 % done. The picture can be a tiff, psd or fff file, it originates from a 6x24 cm rollfilm scan with a Flextight X1. I have absolutely no problems with other PS5 filters or plugins on this files with this machine. A machine with more ram won't help. Even the Kolor machines at photokina 2012 couldn't do the job. Is there any solution in sight??? - or is Neutralhazer a "dead programme" with no servicing anymore?
Please help!
Kind regards, Peter E.
caretaker360
Re: Neutralhazer and big files ... old problem ... no soluti
by caretaker360 » Thu Aug 21, 2014 3:41 pm
Same here. Very large pano getting an program error....
colchagua007
by colchagua007 » Fri Jun 12, 2015 10:34 am
This problem was reported back on 13 August 2013. It is still pending and I am having the same problem and having a wasted time, as I'm processing 16 bit images with Neutralhazer it will abort PS CC as soon as the progress bar reaches about 55 to 60 % done getting a message saying Photoshop is looking foe a solution to this problem, and then just dies. How come that you still selling a program that does not fully work?.
Kind regards,
Rodrigo
Guilhem
by Guilhem » Mon Jun 15, 2015 10:56 am
The question is more: how Kolor can continue to sell a plugin that is no more supported ? No update since years (april 2012), some features requested several years ago without any reply (support of 360°, improvement on processing speed...).
This software is, I think, definitively dead (early adopters shall be very happy). It's a shame, it was a good idea.
leifs
by leifs » Mon Jun 15, 2015 8:23 pm
I bought it, used it and was not very happy. I think it's 32bit and hasn't been updated for years.
Now I do the dehazing in DXO as a part of the raw developing. Works fine :-)
The money for Neutralhazer was wasted :-(
leifs
